Hey Kagey
Old Nov 23, 1999 | 08:46 PM
atving's Avatar
Bet you were surprised at seeing your name in a post huh was wondering if you could tell me what was causing a few things on my AC 500 I noticed the other day when I gave it a lot of gas seems it didn't want to take it like it was running out of gas and has back fired a few times do you think me not turning my gas off at night could be causing this or maybe is the gas mixture a little to lean also seems my Cat is pulling a little to the left is this maybe caused by an adjustment on the front wheels thought I would ask as I have seen some posts on here and you seem to be pretty knowledgeable on atv's thought I would ask you these things as I have to take it in to the dealer while it is still under warranty have 300 miles on it now...thanks
Artic Cat 500 auto...love not shifting
Old Nov 23, 1999 | 09:17 PM
Kagey's Avatar
AT one of the first things you need to check on the pulling to one side is your tire pressures. I have found that the stock Titans and Dunlops are very sensitive to tire pressures being off on one wheel by as little as a half pound, if this does happen to be the case post it back on here to let me know.As for the bogging I am really not familiar with the Artic cat Carb and fuel delivery system there is only one here a Manual shift 500 and I have not had to do anything but install a set of Oxlite CV guards on it for the owner. I would have to say on that new of a machine that its just break in pains(as I like to call them) Likly just a minor Carb adjustment that needs to be made in order to correct your running problem . When you take it to your dealer for the first service be sure you tell them about this problem and let them try to tune it correctly they should have no trouble tuning the Carb in properly on a new machine. Also if the tire pressure doesn't corresct the steering let them line your front end for you . Sorry about my lack of knowledge on the Cats but our closest dealer is 110 miles away and people just won't drive that far with the Honda plant 35 miles away and 3 Honda dealers inside that distance. We also have the largest Polaris Dealer in the state about 20 miles away so you can figure what I see around here all the time. As for my name on a Post , Ha Ha its not the first time its happened. I'm glad to help when I can but unfortunatly I don,t have all the answers and its hard to make a diagnosis over the Internet, lot easier when I can put my hand on the machine.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
Old Nov 23, 1999 | 10:40 PM
atving's Avatar
thanks kevin thanks for the info I will check the psi and let you know I am pretty good at giving legal advice for the obvious reason hehehehe if you need any...later...
Artic Cat 500...Love that Cat
Old Nov 23, 1999 | 10:50 PM
mudmachine's Avatar
Atving...
Are you talking aobut a dead stop "whack" to W.O.T.?... if so, thats called "toggling" the carburetor.. and very few, if any, utility machine carburetors will do that under load.
I haven't seen a broken in Yamaha 4-stroke that will do it... talking about under load..i.e....In gear...
Old Nov 23, 1999 | 11:08 PM
Andy Bassham's Avatar
I agree with Kagey. Just have them adjust the carb. My uncle's 454 would cut out, foul plugs, and puff black smoke (indicates gas) when you revved the engine in neutral. They replaced the plug (because it needed it) and adjusted the carb (which was too rich) and it hasn't done it since. The problems came with 50-125 miles, and from 125 miles to nearly 300, it hasn't had a problem since. Easy to fix, but it will make you wonder at first. Especially with a new machine.
Andy Bassham *(1999 Arctic Cat 500 4x4, 1989 Honda 300)*
Old Nov 25, 1999 | 03:21 PM
BushHog's Avatar
Atving, I'm not trying to insult you,but please use periods. That first post was a really lonnggg sentence.
BushHog
Old Nov 25, 1999 | 07:54 PM
Tree Farmer's Avatar
BushHog, I find punctuation makes posts easier to read and also easier to understand.
I appreciate the consideration a poster shows to his readers when he tries to use correct punctuation, spelling and grammar.
Everyone makes errors, and this ain't exactly English class; however, I believe an effort at good writing improves communication.
Tree Farmer
Old Nov 25, 1999 | 08:04 PM
BushHog's Avatar
Atving,I was only trying to help. Please don't be offended.
BushHog
CHICKENman
Feb 23, 2002 12:15 PM
Kagey
Jan 22, 2000 10:33 PM
Pasqualie
Dec 20, 1999 02:09 PM
JOEMAG500
Dec 13, 1999 11:30 PM
JarrodHolland
Oct 10, 1999 12:29 AM
