Tach on DS instrument panel
Old May 26, 2001 | 03:32 PM
JaviDS's Avatar
Has anyone installed a tach on the DS and what kind would I need?
Old May 29, 2001 | 03:58 PM
jeffnrivercity's Avatar
The tach I got from Ron Wood Racing $225.00 (949)645-0393 It normally is supposed to mount to handle bar clamps,but I didn't like it up that high plus one roll-over and it would be history.Installing it in the dash was pretty easy just cut a hole that fit tight around the tach and put silicone on the backside to hold it in place.The dash needs to be raised up 1/2 inch so the tach can clear the headlight,so at the 2 screws at bottom of the dash I put 1/2 plastic spacers and longer screws.At the top you just slide up the dash and re-tighten the 1 screw. The wiring is set up to plug into the factory harness(no spicing)
tach pic
hope this helps
Jeff
Old May 29, 2001 | 09:13 PM
JaviDS's Avatar
Thanks Jeff...
Nice ride!!!
Jeff Roper
Feb 1, 2022 11:48 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
cody500ho
14
Aug 14, 2015 05:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
