Blaster Brakes
Old 12-27-1999, 01:47 AM
295Blaster's Avatar
I need to upgrade both front and rear brakes now due to the better performance of the new engine kit. I have seen the rear hyd. kits but none for the front. Will the warrior or Banshee front set up work with minor modifications. And how good are the rear kits, it seems like I could possibly use the rear set up off the Banshee with some minor mods to the frame for the fluid resev. and the pedal area. Has anyone tried it yet ?
Old 12-27-1999, 12:17 PM
Blaster668's Avatar
I have Hydros all around. The Banshee and warrior brakes work for the front but you have to make brackets for the caliper to bolt on to the spindle where the tierod connects.
I have the Trenga kit on the back and it works pretty good But I would reccomend adapting them from another quad.
Garrett Lowman; CT240 Blaster, YZ490
Old 12-27-1999, 04:54 PM
Kiwi-Craig's Avatar
Brakes
Check out Mello ATVings neat article on a do it yourself fit up based on Honda 350 bits
http://www.uslink.net/~philzie/bb1.html
the team at Blaster central had a lot of hassles with there trenga setup so maybe look elsewhere if you are after a kit setup…………
http://www.geocities.com/Baja/Canyon/2536/
Blaster central have also looked at front brake conversions so check em out.
Kiwi-Craig
Crainic@ihug.co.nz
Joe454
11-20-2020 01:19 PM
EIF
04-20-2017 07:15 PM
Whitelx1
10-02-2015 10:55 PM
Ahtatu
09-28-2015 12:14 PM
nastyblaster100
09-13-2015 01:19 PM
Quick Reply: Blaster Brakes
