clutch dragging???
Old Oct 18, 2001 | 11:09 PM
real4x4's Avatar
on my friends 2001 sportsman ho/// when you put it in gear and at idle it will pull out and go 5 mph.how do you fix this problem????
Old Oct 19, 2001 | 06:31 AM
PITB's Avatar
first look to see if it iddle to high. Than change the belt. Then if it still does the problem, I would clean every component in the clutch assembly and if it still does it, you may have clutch problems. I found that if you don't know about clutches that it's easier to take it to a good dealer and have it fixed.
my 2 cents
Old Oct 19, 2001 | 08:27 AM
real4x4's Avatar
we have lowered the idling and installed a new belt and it still trys to pull out without giving it gas.any one else know what it could be??
Old Oct 19, 2001 | 11:38 AM
gregsims's Avatar
Take off the belt housing and put it in gear. Watch to see where the belt is touching the primary clutch. If it is rubbing the inside of the driven clutch, you need to add a shim to the inside of the driven clutch. If it is rubbing the outside, you need to remove a shim... You will see what I mean. It is what we call clutch creep. Your clutches are not lined up properly... That is my guess anyway.
Greg
Old Oct 19, 2001 | 12:34 PM
bubba1005's Avatar
This is a common problem. You can do one of two things to fix it. You can either Shim your secondary clutch by placing a shim between the two sheeves.(The right way to do it)
Or you could put a Scrambler belt on it 3211077 I think is the part #
The scrambler belt will work fine and won't hurt anything, However because you have EBS on it the srambler belt will get a little chewed up over a period of time because of the different style cogs on the belt.
I've done both with good results.
Old Oct 20, 2001 | 01:06 AM
SHAGGY500HO's Avatar
Looks like gregs got you covered. [img]i/expressions/face-icon-small-happy.gif[/img]
"You can either Shim your secondary clutch by placing a shim between the two sheeves.(The right way to do it)"
bubba1005
The service manual lists Pn# 7556401 that can be added or removed from behind the driven clutch. Adding more shims between the sheaves of the driven clutch.(Is the wrong way to do it) Is the belt for the Scrambler longer or shorter? Why would it be a fix for clutch creep?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
