i need help with a stripped lugnut.
Old Oct 30, 2001 | 11:05 PM
Sportax300EX's Avatar
Ok,
I know this sounds stupid, but i have tried everything to get this stripped lugnut off my 300ex front tire. i have used wd40, an airgun, different sockets, and tonight i broke a breaker bar trying to get it off. the bolt is pretty much rounded all of the way around.
Any suggestions will be appreciated.
Thanx
Old Oct 30, 2001 | 11:21 PM
BDuTcH300EX's Avatar
take a big hammer and whack it a few
Old Oct 31, 2001 | 10:56 AM
IceMan11's Avatar
I'd make sure you're using a 6 tooth socket and not a 12 tooth socket. Makes a big difference. If the nut is really rounded off, break out the torch...
Old Oct 31, 2001 | 11:04 AM
I thought about bustin out the torches but there is one drawback.
My aluminum rim would be junk after the torch was used by it.
Old Oct 31, 2001 | 11:05 AM
sAyIt_fmf's Avatar
I think everyone has probably stripped a nut now and then.
If you have dremal, Make a small slot in the nut...Get a nice sharp chizel and give it a crack. It will break. Just be careful not to ruin the threads in the process. But don't fret...even if you wreck the threads on the stud. A new one for that machine can be had for around $5.
Old Oct 31, 2001 | 01:13 PM
Camo-man's Avatar
I had the same problem,, I used the dremel like it was suggested,
but i cut a slit in each side of the nut, and i just fell off, when
i tried to turn it with vise grips......
tysonbully
Sep 28, 2015 02:30 AM
ny250r
Apr 27, 2001 06:11 PM
Bayou3004x4
Mar 22, 2001 03:20 AM
brokemybanshee
23
Jan 6, 2001 12:37 AM
