Need clutch puller
Old Dec 24, 2001 | 03:57 PM
ScramberShadow's Avatar
I've been looking for a puller from my dealer but he doesn't stock them and tells
me he can order one but it could take up to 4-6 weeks to get one. Some thing about polaris is redoing their tooling division or some kind of crap like that.
If you've ever taken you clutch off, then you know that these pullers are just a bolt you screw into the clutch and tighten to push it off the crank. does anyone know what size this bolt is and where i could possibly find one.
Old Dec 24, 2001 | 04:24 PM
SHAGGY500HO's Avatar
The threads are 3/4 inch fine thread pitch. I have used the bolt and 3/8 socket extention several times. Works well and cost a $1.00. Just make sure the extention is bigger than the bolt hole in the crankshaft.
Old Dec 24, 2001 | 04:33 PM
ftwflh's Avatar
Try ebay i got one off there and it cost me $20 but i had to wait a week
Old Dec 24, 2001 | 10:33 PM
AZ400L's Avatar
HPD can get you one in 2-3 days, $20. I believe you'll need a 7/8 socket, not 3/8. I have one and will measure it tomorrow if I can.
Old Dec 24, 2001 | 10:57 PM
thanks for all the info...im as cheap as the next guy and I like that 1.00 price tag.
Im going to try shaggys idea. Correct me if im wrong, but its just a fine pitch 3/4" bolt? When I taked to my dealer, he told me it was a metric size bolt. Now do you think he would tell me that just so i had to buy one?
Old Dec 25, 2001 | 12:09 AM
ScramberShadow
I picked up the one I use several years ago at a local bargain type surplus store. I couldn't remember the size at first. So the size info I gave was from a post of farm123's. My brother is in possession of mine so I can't double check it.
AZ400L
I was referring to a 3/8 ratchet extension to be used as a spacer between the bolt and the crank. Put the large end in first btw.
Old Dec 26, 2001 | 08:44 AM
Rammer's Avatar
All I use is a piece of 3/4-16 all-tread thats 9" long with a nut welded on one end.
Old Dec 27, 2001 | 10:37 AM
walexa's Avatar
You can even buy a hitch ball with 3/4" fine thread.........and use a 3/8" extension. I used a 12mm socket attached to the end of the 3/8" extension, along with the long shank hitch ball. Kinda jimmy-rigged, but it worked.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
