Clutching
Old Jan 2, 2002 | 10:58 PM
Madscrambler's Avatar
I was wondering about some differnt clutch cobos I am running a 400 with a brown primary with a violet in a roller with 56 gram weights.
Old Jan 2, 2002 | 11:21 PM
AZ400L's Avatar
Uhhh...gonna need some more info as to what motor mods you have and your riding preferences.
Old Jan 3, 2002 | 01:00 AM
SORRY I just have a low end pipe delta force reeds k&n filter.
Old Jan 3, 2002 | 03:10 PM
genekell's Avatar
How much difference does clutch work make?
Old Jan 3, 2002 | 07:03 PM
ftwflh's Avatar
your clutch set up will greatly improve your performance if you set it up for YOUR type of riding.I have my 2 stroke set up to pull and mud with.My 425 is set up for trails.
Old Jan 3, 2002 | 07:07 PM
AZ400L's Avatar
Clutch work = efficeint power transfere from crank to rear wheels. It means a lot and is very misunderstood!
Madscrambler, given the information you gave one can only make suggestions at best, as two indenticaly modded machines may not perform equal with the same clutching.
#1 You say you have a low end pipe? Why use the Brown spring which engages fairy high, especially on a non-ported motor? I sould suggest you try the Orange from RCR/HPD. I didn't goto a Brown untill I had HPD trail porting.
#2 You may be OK with the 56gm weights, try putting the OE S55gm back in with the Orange.
#3 The angle of helix you have would be usefull to know here, I would suggest something like a 42/38.
#4 The violet secondary is a good spring to use, what position do you have it set too?
#5 Make sure your clutches are aligned. If not properly aligned the belt can bind causing friction, the worst enemy to a CVT tranny.
#6 Clutching is not an exact science and all of the above are merely suggestions, not concrete answers to your question. Clutching is a huge pain in the ****, hence why it is most often overlooked and neglected. There is NO specific answer to your question, its a matter or time and tuning.
Old Jan 3, 2002 | 08:01 PM
ftwflh's Avatar
hey AZ400L I have a set of springs that are new and i am not going to use them.I have them on ebay right now with no bids.They are EPI red primary part#PATV1 and purple secandarypart #PDS-6 if they dont go i would make a good deal on these if you know someone who needs these.I am not sure what these do and dont want to try them because i like the set up i am running.If you know what they are =to let me know.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
