Anybody have any Cannibal Problems
Old Jan 13, 2002 | 08:55 PM
02CannibalRider's Avatar
I just want to know if you guys have had any problems with your cannibal? What should i b aware of? What oil should i use when oil is time to be changed i was thinking klots? Im picking up mine wensday.
Old Jan 13, 2002 | 11:32 PM
YoDaddy's Avatar
Change your engine and transmission oil after the first hour of use and if for some reasone your Dale won't start after you have ridden it a few times, you prolly fouled your plug. I have done it twice and have heard of a lot of people do the same thing.
Old Jan 14, 2002 | 07:01 PM
how hard is that to do so i <u>have</u> t e fr an hour than change it this is nt killer 400ex i was jus wondering because jus picked mine up today. so i have to change it after and hour wat should i buy like the liquid for it and how hard is it to do im totally new to fourwheelers and alls know is annonale is very good so wouldu help me.
Old Jan 14, 2002 | 07:10 PM
briansgi's Avatar
Oil to use:
Transmission, I use Honda's HP2 transmission oil, weight is 80/85W
Crankcase, I use full synthetic 10W40 such as Castrol
The back of your owners manual will tell you what oil to use and the amounts.
And change both quite often!!
Also visit cannondale's web site, they have a pdf file you can download which describes in detail the proper procedure to use when starting your c'dale, here is the web site that has this info:
http://www.cannondale.com/motorsport.../techtips.html
If you do not follow this, it's easy to foul your plug!!
Old Jan 14, 2002 | 08:04 PM
i ws thinking about lotz and how often do i have to change it?
Old Jan 14, 2002 | 08:21 PM
JayBR's Avatar
I put my first hour on mine this morning, changed the oil this afternoon and went riding a coule more hours.
It's not hard to change, but not as easy as my Polaris, the only problem I had was finding a peice of hose for the drain on the right side frame. I used a short piece of old garden hose just to get by. You also need an air compressor to clean the filters. I used Honda HP2 in the trans and Module 10W40 in the engine.
Old Jan 14, 2002 | 08:26 PM
what about klotz
Old Jan 14, 2002 | 08:35 PM
briansgi's Avatar
I know alot of people who use Klotz in their 2 strokes and I'm sure Klotz makes a good 4 stroke oil. The nice thing about the C'dale's, since the transmissions and crank case are separate, just like your car or truck, you don't have to go out and buy the high dollar motorcycle type oils like Klotz and Maxima's 927. If you choose to use &quot;normal&quot; automotive type oil for the crank case, do use at least a partial synthetic or full synthetic oil. I use a full synthetic 10W40 and I pay around $4.25/quart, and the best part, you can find these at walmart!!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
