port and polish!
Old Mar 12, 2002 | 08:28 PM
bluekawirider2005's Avatar
about how much more power would i get if i port and polished my lakota and how much would it cost! and what is all needed to do it? info is greatly needed! thanxs (i love my lakota)
Old Mar 12, 2002 | 08:34 PM
Mxracer98's Avatar
I got mine done to my Mojave for $150, but i also had new springs and valves put on, I would say maybe 2-3hp.
Old Mar 12, 2002 | 08:41 PM
can you feel the change? is it worth it? i think i mite look into it!
Old Mar 12, 2002 | 08:52 PM
Mxracer98's Avatar
If you are doing that you might as well do other things to your engine. I couldnt tell because when I got it port and polished I did other think like race-cams new piston. But overall if was way more powerful. like day and night
Old Mar 12, 2002 | 08:56 PM
Kawi250's Avatar
Remember the Mojave has double of everything the lakota has (like valves, cams) so I guess the Mojave would benifit more.
MXracer98,
Can the difference in speed be felt? What about hard hitting acceleration. Ohh yea what grind cams do you have??
Old Mar 12, 2002 | 09:21 PM
gaff's Avatar
The problem with the lakota is it won't rev out, if you short shift it about 2/3rds throttle you will find more power. One thing that can be done is lift your front hood off, here you will find a snorkle cap that covers the air intake, another way would be to eliminate the air box and put on a clamp on air filter, but that can be risky to water entry.
Port and polishing is a huge answer for the lakota, but port and polishing will suffer graetly to the bottom end. Answer, higher comp piston, and then you can opt for a cam later.
Sense the lakota has a side entry cam and heavier valve springs aren't needed you can swop cams at any time.
If your searious about port and polishing and a high comp piston, email me and I'll do it for ya!!!!!!
Old Mar 12, 2002 | 09:35 PM
hey where can i get all of this stuff at for cheap?
Old Mar 12, 2002 | 09:36 PM
Mxracer98's Avatar
The diffrence in my Mojave now is like night/day compared to a stock mojave. We dragged them and the stock Mojave was destroyed. Acceleration hits pretty hard mid-top range, but you have to rev it and it loses a little bottom end to. I have the web-cam, race cams mid-top range I cant remember the grind number.
Old Mar 14, 2002 | 10:18 AM
98Lakota's Avatar
When I rebuilt my Lakota I had the head ported and polished along with stiffer valve springs. Gaff is right about loosing some bottom end, but the difference in the top end is like night & day. I ended up going back to the 12 tooth front sprocket to get my torque back. Now it pulls hard from the bottom all the way to the top.
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
