ES floorboards on manual shift Rancher?
Old Feb 23, 2000 | 01:12 AM
RonP's Avatar
Has anyone tried to put the floorboards from the ES on a manual shift Rancher?
At first glance, it seems like the floorboard on the foot brake side would not be a problem. It's the shifting side of the ATV that seems questionable. Could the shifter be adjusted upward to allow your foot to fit between the floorboard and the shifter? Any help would be greatly appreciated.
Old Feb 23, 2000 | 02:00 AM
Bob4x4's Avatar
A friend put es floor boards on his 450s, they bolted up with one exeption. The s lacks the two threaded bolt holes on the front of the frame. A drilled and tapped 3/8" aluminum spacer and u-bolts, was all that was required to bolt up the front support. The shifter clears as is, but could be adjusted higher if you felt it was too low. I know you asked about a Rancher, but I thought if it works on the 450's, it will most likely work on the Ranchers.
Old Feb 23, 2000 | 03:15 AM
gokrtkilla's Avatar
why do u guys need floor boards ? i dont have any on my 86 3504trx 4x4 i dont even have IFS !
Old Mar 16, 2004 | 03:42 AM
Lococoin's Avatar
Default ES floorboards on manual shift Rancher?
Bob4x4 is there any way i can take a look at some pictures of these custom brackets you made for the 450? I am interested in doing a conversion on my 450s.
Thanks
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
