ES floorboards on manual shift Rancher?
Has anyone tried to put the floorboards from the ES on a manual shift Rancher?
At first glance, it seems like the floorboard on the foot brake side would not be a problem. It's the shifting side of the ATV that seems questionable. Could the shifter be adjusted upward to allow your foot to fit between the floorboard and the shifter? Any help would be greatly appreciated.
A friend put es floor boards on his 450s, they bolted up with one exeption. The s lacks the two threaded bolt holes on the front of the frame. A drilled and tapped 3/8" aluminum spacer and u-bolts, was all that was required to bolt up the front support. The shifter clears as is, but could be adjusted higher if you felt it was too low. I know you asked about a Rancher, but I thought if it works on the 450's, it will most likely work on the Ranchers.
