Need help with spsmn 500 clutch!
Old Mar 29, 2002 | 03:35 PM
eb's Avatar
eb
I want to put a more aggresive clutch spring in my 500.Do I need a clutch puller or does anyone know another way to get it off?Also,what color spring would be good for better acceleration without the hesitation?THANK YOU
Old Mar 29, 2002 | 04:04 PM
MagNumMan696's Avatar
I just did it to mine all you have to do is remove every thing like if you had to change the belt and there are 6 bolts on the primary clutch that should expose the spring but on some models u have to take the large center bolt on but before you take this off make sure you find the x's on the cluth these Must be lined up when you reassemble just put your new spring in and tighten every thing to spec and put your covers back on and your done well was that so hard?
Old Mar 29, 2002 | 04:05 PM
i used a red spring
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
