Need help with spsmn 500 clutch!
I just did it to mine all you have to do is remove every thing like if you had to change the belt and there are 6 bolts on the primary clutch that should expose the spring but on some models u have to take the large center bolt on but before you take this off make sure you find the x's on the cluth these Must be lined up when you reassemble just put your new spring in and tighten every thing to spec and put your covers back on and your done well was that so hard?
cdstang
08-31-2015 07:52 AM
