sp 700 diagnostic
Old Apr 8, 2002 | 11:44 PM
explorambler's Avatar
Have 37 miles on my new sp700. ran the diagnostic as per owners manual.
After warm up
Idle is 1040 to 1070 rpm
Battery is 13.3 volts
Oil pressure reads low but there is lots of oil.
going to take it to the dealer tomorrow.
Any one have similar reading on there machine
Old Apr 9, 2002 | 12:34 AM
shopman's Avatar
Do you have the oil sender on yours I haven't seen anybody say they had the sender so the oil pressure mite not work in the diagnostic mode check and see if you have sender mine just has plug in block
Old Apr 9, 2002 | 01:08 AM
I have version 1.8 on the diagnostic and may have made a mistake reading the info as it does show a box in the upper left of the screen with an arrow of sorts below it. this probably means oil pressure normal. only captain kirk can figure out the symbles they use for oil pressure on this ship. probably japanese for oil pressure!!. I don't know if there is a sender connected or not. I would not know where to look for it. The only sending unit i see is the engine temperature sender I think as it is on the left side just under the rad hose on the side of the cylinder.
Old Apr 9, 2002 | 06:46 PM
shopman's Avatar
The sender would be right above the dipstick mine has a litte allen plug there. the sender would be there if you have one. the box on mine is hight too but I found the sender wire and grounded it and it goes low or if not in the diagnostic mode the oil symbol goes on if grounded.
Hope that helps
Old Apr 9, 2002 | 10:07 PM
shopman,
above my dip stick is a sender with a wire comming from it, but it is a sender for the engine temperature, so says the shop mechanic. I am going to remove the front body cover tomorrow and trace the wires back to locate weather there is one or not.
I'll let you know what I find.
Old Apr 10, 2002 | 02:00 AM
shopman's Avatar
explorambler below the water temp and the frost plug just above the oil dipstick is where my allen plug is that is where the shop manual shows it if you have it looks to be 1/4 or 1/8 plug
if you look
Hope that helps
speedbuff
13
Nov 11, 2020 10:16 AM
Sw00p
Sep 24, 2015 02:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
GoingVirtical
Oct 12, 2008 08:59 AM
embler
Sep 13, 2007 12:34 PM
