steering stem has 1" vertical pull
Just a quick question, my steering stem is moving up and back down by about an inch, so do I only have to replace the lower steering post support block or do it have to replace the upper bushing too??
Thanks for the answer in advance,
ON MY '96 TRAILBOSS,THE SAME THING HAPPENED,BUT IT DIDN'T MOVE A WHOLE INCH.THERE IS A RUBBER WASHER BETWEEN TWO STEEL WASHERS AND IT SOMETIMES GETS PUSHED OUT.I REPLACED MINE WITH A THIN "SLICE" OF PVC PIPE AND THAT SOLVED THE PROBLEM.
I have a similar problem with my Xplorer. Chech out this site re a replacement steering post support block.
https://atvconnection.com/editor/rev...g/steering.htm
