steering stem has 1" vertical pull
Old Feb 28, 2000 | 05:39 PM
myscrambler's Avatar
Just a quick question, my steering stem is moving up and back down by about an inch, so do I only have to replace the lower steering post support block or do it have to replace the upper bushing too??
Thanks for the answer in advance,
Old Feb 28, 2000 | 06:03 PM
BIGFOOT's Avatar
ON MY '96 TRAILBOSS,THE SAME THING HAPPENED,BUT IT DIDN'T MOVE A WHOLE INCH.THERE IS A RUBBER WASHER BETWEEN TWO STEEL WASHERS AND IT SOMETIMES GETS PUSHED OUT.I REPLACED MINE WITH A THIN "SLICE" OF PVC PIPE AND THAT SOLVED THE PROBLEM.
Old Feb 28, 2000 | 07:56 PM
sportsman400's Avatar
I had the same thing happen to after a jump.I used a piece of tire sidewall to replace the rubber.
Old Mar 2, 2000 | 07:39 PM
motorman's Avatar
over greasing the bottom bearing will cause the rubber seal to be forced out and over the steel washers. do not over pressure when greasing that bearing.
Old Mar 3, 2000 | 07:06 AM
Loyal's Avatar
I have a similar problem with my Xplorer. Chech out this site re a replacement steering post support block.
https://atvconnection.com/editor/rev...g/steering.htm
Old Mar 6, 2000 | 10:41 AM
It's fixed! I ordered the Hotseat Lower support block. After pulling my stem out I noticed it was bent oh well what's next? The hotseat lsb worked great and was easy to install. Thanks for the replies,
toonces
Aug 13, 2015 12:40 PM
Sportsman850
Jul 31, 2015 04:25 PM
Gtsordo
Jul 22, 2015 01:27 PM
mdrkcckv
Jul 22, 2015 09:10 AM
1966F100
Jul 12, 2015 03:01 AM
