sp 700 diving problem
Old Apr 23, 2002 | 10:45 PM
explorambler's Avatar
all of us with an sp700 will know that when you corner (especially down hill turns) the front end wants to dive and roll over on the front tires. This makes the back end want to come up and that roll feeling comes on. Well I just fixed that on mine. Cost $00.00 I took a piece of 2" galvanized pipe (of course!! Im a plumber) cut it to 7/16ths inch with a cut off saw. Rasped the rough edges and put it under the front springs. This added preload to the springs and no more diving and twice the steering control. bump steer is reduced. It feels more like my scrambler 500. Hi speed cornering is much more stable also.
Old Apr 24, 2002 | 09:56 PM
Jack's Avatar
Polaris makes spring rubbers for that purpose also.
Old Apr 25, 2002 | 10:37 PM
Hairback357's Avatar
Yep I bought me the rubber sping spacers and they work like a champ.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 26, 2002 | 04:15 PM
sportsman43's Avatar
yes i have noticed that with my sp700,,,
i am wondering why the 7/16 thickness?? as i am thinking about doing the same thing to mine.. and what was the procedure??
thanks for the info..
sp700,,feel the power,,
Old Apr 26, 2002 | 11:36 PM
sportsman 43, in responce to your reply. I measured the sag when i got on the machine at 9/16" then decided to try and eliminate all but 1/8 " sag. That is how I ended up cutting a 7/16" piece. You can try any spacer width you like. Be carfull when you disconnect the top shock assembly. don't drop it to far down or the yoke will come out of the wheel housing and you will have to do a lot more disasembly to re connect it. unfortunatly polaris puts a snap ring on the end of the spindle that is totally usless and servs no purpose except it fustrate thoes of us that want to do some wrenching of our own. You will have to compress the spring before disconnecting it. the right tool will save you a lot of frustration. I did it with rachet tie downs.
I used a chop saw with a blade to cut the 2" galvanized pipe to exact length then filled the burrs off. placed it under the ring on the bottom of the spring and re-assembled. good luck.
Old Apr 28, 2002 | 01:29 AM
4xWhore's Avatar
why the explorer floor boards, and what is ex plastic.
have you had trouble with your bike. friends has had new cv, needs new iner rod ends,and is in the shop right now for new front differensial,carb boot, wont idle, 1000 miles stock tire. warrentee is out now but they are gona cover this stuff some how,
poo , they leave every thing in the dust even their own parts.
betheviper
scott
Old Apr 30, 2002 | 02:24 PM
I changed the floor boards because of the area I ride In. lots of bolders and tight trees. the plastic factory boards are well over 200 dollars (can) and break vary easily the same with the fender flairs so the went too. Note: everyone check the body screw on the left side between the fuel tank and the seat. the screw is too long and wearing a hole in the inlet snorkle to the air box. I seen this on all the sp700 in this area. I have to check out a problem with my clutch as I have no top end.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
