Sportsman 500 front diff. teardown
Old May 3, 2002 | 08:31 AM
pprash's Avatar
I have a SP500 that has one side's output shaft Sheered off. Anyone ever tear down the front diff? Is that shaft a solid one that drives both sides that can be replaced?
Old May 3, 2002 | 09:07 AM
hodaddy's Avatar
when you say sheared do you mean that the male splines are wore down and the yoke (female splines) that swallows the shaft is is looose and you dont have 4wd on that side. if that is the case you can put a bolt 5/16 and nut thru the yoke and shaft and it will keep pulling.
Old May 3, 2002 | 09:11 AM
pprash's Avatar
The shaft is sheered off. In fact it broke across the point where the bolt hole is. Massive wreck.
Old May 3, 2002 | 09:34 AM
hodaddy's Avatar
its is a solid shaft that has a gear in the on it if i remember they are about 200 dollars that is not counting the seals or the yoke if it is wrecked they are about 60 dollars. if the u joint is also messed up you can get them at auto parts store about 15 dollars vs 30 dollars at polaris
Old May 3, 2002 | 09:38 AM
pprash's Avatar
More bad news. The drive shaft is completely gone!
Old May 3, 2002 | 09:39 AM
pprash's Avatar
do you split the diff. case to replace the shaft?
Old May 3, 2002 | 09:42 AM
hodaddy's Avatar
you can go to partsland.com and look at the diagram they sell polaris parts. the bearings and seals you can get at a bearing service store.
Jmuddin284
Jan 19, 2026 07:16 AM
traumajunkie
Jul 5, 2015 03:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
