Wolverine Problems Need Help
Old May 9, 2002 | 09:04 PM
mudmagnum's Avatar
Came off of a jump and when I landed i messed something up. Now when you give it gas it pops but idles fine. Any idea what happened?
Old May 9, 2002 | 09:30 PM
Juice's Avatar
What do u mean it pops but idles fine?
Old May 9, 2002 | 11:07 PM
KNOWSALOT's Avatar
The Facility
OK..We are talking Yamaha here.
Two things to check.
First,..It could be that the ignition is retarded. Check the park brake switch on the handlebars an all of the circuitry coming from it.
Secondly,...check to see if the intake boot between the carburetor and engine is still intact. You didn't say what year model Wolverine you had. The older ones use a different intake from the later ones and when they start to deteriorate, it will seperate from something like a jolt,..or a jump as you describe. It leans the mixture severly and will run poorly above idle, if it runs at all.
If you have the later one, it still could be that the intake has seperated, but usually remains somewhat intact since it is the bolt on type rather than clamp on.
I would check these items first, and if you still can't find the problem, post back with a more thorough description including WHEN it actually started running poorly. [Immediately after the jump??]
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
