warrior clicking
Old May 17, 2002 | 06:27 PM
paintblaster41's Avatar
my warrior has a clicking down in the gearbox it i think thats were its coming from could there be a tooth broke off. last time i changed the oil it had fine shavings in it. whats wrong befor I start to tear it down i need a clue.
Old May 17, 2002 | 06:50 PM
warrior007's Avatar
Some fine particals in the oil are normal, but warriors have a problem in a cluster gear in the back of the trans - the bearings in this cluster gear work there way out of the gear and bind on the cases. If you warrior does not push around the garage as easy as other quads and you have aluminum shavings I would definitely have that checked - after a while it can ruin the cases.
The clicking noise can be alot of stuff besides the transmission though, check for a broken front sprocket tooth or bad chain roller
I would put it up on a jack, start it up and put it in gear to also help find the problem.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
