2 mounth old Sportman 500 oil in air box and other ...
Old Jul 2, 2002 | 10:00 AM
hotdog's Avatar
I don't like that the engine brake only works on the back wheels..because the front wheels don't lock unless the back wheels slip..This is bad for going down steep hills..the back wheels tend to lock up..makes it tricky..
I noticed the guy I ride with Honda 350 never had this happen..But I was using the back brake and likely should have used the hand brake as this works on all four wheels..This was confirmed by the mechanic at the dealership..
I also had oil in my air breather box ..He said this is caused by 1 having it over filled or 2 tipping it on it's side..I was in a coulpe of spots where it was leaning quite far but nothing that I thought was that bad...Anyone else have this happen..
Old Jul 2, 2002 | 09:35 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I rolled mine on its side and oil got in the airbox. Not a real big deal unless the filter got soaked with oil.
Old Jul 2, 2002 | 09:49 PM
archerr2002's Avatar
Your crankcase has a breather hose into the airbox. Every now and again it coughs a little oil into the airbox, this is normal. There should be a drain in the bottom of the box, just pull the plug out of it and it will drain out. My Trail Boss does the same thing.
Work to live, live to ride!!
Old Jul 3, 2002 | 07:27 AM
mtpockets's Avatar
Hotdog,
the way i understand it the rear brake is a 'back-up' only. to be used only if the hand brake fails.
the dealer should have told you this at the time of delivery.
that ABS working the rear wheels only can definately cause some hairy down-hill rides! take-em slowly!
ride safe,
-MT
Old Jul 3, 2002 | 07:07 PM
stuckinmud's Avatar
I'm not sure about a Sportsma but my Trail Boss was getting oil in the airbox too. I discovered the transmisson has a breather tube that runs into the airbox. The dealer overfilled it when it was being serviced. I drained a little fluid out of the transmission and the problem was solved.
Jeff
Old Jul 4, 2002 | 10:24 AM
MUDFUN's Avatar
Hey hotdog, do a search on this forum and type in '4 wheel EBS' there is a post there about how to do it. Hope that helps you
Old Jul 4, 2002 | 11:22 AM
92LT's Avatar
<< dealer overfilled it when it was being serviced. >>
Same thing happened to me except it was on my kawasaki. The dealer overfilled the oil during first service and the oil went in the airbox via the crankcase breather tube during a ride. Check oil levels.
Jazperman
Aug 7, 2016 08:12 PM
Grizzly2003
May 28, 2003 08:46 PM
Sportmanrider90
May 26, 2003 10:01 PM
Grizzly2003
Apr 22, 2003 06:30 AM
Sportmanrider90
Mar 25, 2003 07:18 PM
