Cut sidewall on tire, any hope?
Old Jul 16, 2002 | 10:57 PM
soupcan's Avatar
I developed a half inch cut in the sidewall on one of my front tires. Is there a remedy for this or is it dumpster time for the tire. It has 3/4 tread yet.
Old Jul 16, 2002 | 11:47 PM
Conkster's Avatar
You can try to put a couple of tire plugs side by side in the hole that might work. Hope this helps
Old Jul 16, 2002 | 11:54 PM
barkbiterds's Avatar
Take it to a tire shop, have it patched from the inside. Tube it for good measure. $10-$15.
Old Jul 17, 2002 | 12:30 AM
ftwflh's Avatar
I had the same thing happen and I put in 3 plugs and it has held for the past 2 months of riding.
Old Jul 17, 2002 | 08:40 AM
MUDFUN's Avatar
I had to put in two plugs in next to each other on the sidewall and it's still holding after a year.
Old Jul 17, 2002 | 03:41 PM
BUBASCRAMBLER's Avatar
DO NOT plug the tire. You will only be asking for it to let you down.
The only way to take care of this 1/2 cut is like BARKBITERDS said, Patch it from the inside. and then put a proper size tube in it.
This should take care of the problem.
No tire manufacure recommends plugs, Much Less Double or triple, It may work for a short time but it will fail.
Old Jul 17, 2002 | 06:12 PM
ftwflh's Avatar
Hey Bubba we aint talking about a high speed tire here just an ATV tire.And a used one at that by the time you break it down and buy a tube you could almost get a new tire so plug away at the old ones ride the heck out of it and keep plenty of plugs and air in your truck.Oh by the way I have been doing this for many years and I get by real good.
Old Jul 18, 2002 | 01:42 PM
Elrancho's Avatar
Low pressure tires like ATV/tractor tries can work fine with sidewall plugs, and if your plugs fail well that just because you're not using the right thing. The tarred rope plugs is the best I've found for small holes, they just don't leak or come out. For a half inch gouge I'm not sure what I'd use, probably inner patch and tube, but then a tubes very vulnerable to minor thorn holes where tubeless tires aren't.
(BTW Bubbascrambler, ever consider that tire manufactures want to sell more tires?) I've run radial high pressure plugged tires as far as 200,000 miles after the repair( Michelen X series HD tires), and low speed/pressure rope plugged for a while now(perhaps 1700 atv miles.)
Bratman2
Aug 6, 2022 01:42 AM
Ean
Aug 28, 2015 09:39 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
