Rancher no reverse
Old Mar 19, 2000 | 06:47 AM
Gabby's Avatar
Went out yesterday with my wifes 350 Rancher ES . Most of the ride reverse wouldn't click in so I had to use the manual shifter . Every once in awhile it would work . My question is , has this been a problem for anyone else .
Old Mar 19, 2000 | 11:19 AM
Kirk_D4's Avatar
I don't have a Rancher, but I have a 450es. Sometimes when mine is cold or if it is idling a little fast it won't go in reverse. You might try turning the idle screw down a bit and see if that helps. I believe the ESP prevents you from going into reverse if the motor is idling to fast.
Old Mar 19, 2000 | 04:03 PM
phalynx's Avatar
I had this problem the other day. The problem is the reverse sensor on the bottom of the transmission. If you look on the bottom back of the motor you will see a little wire with a rubber boot on it. This connection gets loose and doesn't make contact. I cleaned and reconnected the wire and it works great now.
Old Mar 19, 2000 | 05:21 PM
Gabby's Avatar
Thanks phalynx . Did what you said and it has been fine ever since .
Old Mar 20, 2000 | 03:47 PM
JMMXG's Avatar
The above info is just another reason I like this place besides the good people.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
