Prairie 650 choke cable
Old Aug 18, 2002 | 12:09 AM
jefffoxsr's Avatar
I put on the new choke cable. I didn't see a difference between the new one and the old one. I know the old one was bad because I verified the sticking once I had the quad apart. Now the quad doesn't smoke any more with the new cable in.
Did you guys notice a difference between the old cable and the new one??
Thanks
Old Aug 18, 2002 | 05:34 AM
TrailHog's Avatar
Good to see ya on here again. You was the one we all ask questions to when I first signed on, we could use your wisdom on here more often again. I haven't changed my choke cable, but I have 720 miles on it and everything still seems to run like new except that belts squeals on take off. Another thing is that when I first got it I had to give a little throttle to crank, but now it cranks without having to, hot or cold.
Old Aug 18, 2002 | 09:11 AM
nyroc's Avatar
Is the reason your new cable slide easier because it is made differently/better?
Did you just ask for a new cable, or is there a special part number you need?
Old Aug 18, 2002 | 10:10 AM
jefffoxsr's Avatar
Thanks Daniel,
I haven't touched the quad this year until recently. I'm slowly getting back into it. I need to find some people to ride with.
Nyroc,
The new cable had a sticker on the bag with the new part #. Now that it's back together I haven't tried to work the choke with the handle since I broke the handle accidentally and have to order a new one. When I used the pliers to work the assembly it seemed to work a little better.
Thanks guys
Old Aug 18, 2002 | 11:11 AM
roscoe69's Avatar
Jefffoxsr
Did you chech to see where old cable was sticking and did you replace the springs?
Raymond
Old Aug 18, 2002 | 06:58 PM
jefffoxsr's Avatar
I didn't take the time to see exactly where the old one was sticking. I have not yet ordered the new springs yet. I do need to order a new handle though.
Old Aug 19, 2002 | 12:27 AM
alltoys's Avatar
jeffoxsr I think I went over this with you before a couple of weeks ago yes. Just for a refreshor the cable liner is different more flexible and the bend to the carbs is slightly different, I think a little longer to boot. Here are the spring numbers again if you wish they are from a KLR bike a little longer, thicker wire and work well. They are
16C063
920B1-1720 Called a SPRING PLUNGER
Here are some other numbers you may as well have them all
BB01000 3349551
16.17.41 0111
I hope this helps keep the sunny side up and yes it is nice to see you back on the forum.
Old Aug 19, 2002 | 08:58 AM
nyroc's Avatar
How do you get this cable? Do you just ask for a stock choke cable (54017-1219) and this is what you get from the dealer, or do you have to ask for something special?
Old Aug 19, 2002 | 09:51 AM
jefffoxsr's Avatar
Thanks guys,
To get the new cable I called kawi customer service. After telling them my story they reluctantly said they'd pay for the new cable. I called the dealer and gave the dealer the kawi rep phone number. That's it.
ReconBayou
Oct 16, 2019 02:24 AM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
