lectrons
i just bought a set of lectron carbs for my banshee my motor is compleatly stock does anyone know if it will run right on alky i will prolly get my head milled first anyways but will i need any port work before it will run right
Portwork helps, but isn't neccesary. Milling the head is a must. You will need the added compression for alky to burn clean. I am not familiar with the Lectron pieces, but the trick setup for alky includes a booster jet. It is easy to blow a motor while trying to jet a 2-stroke for alky. A specifically designed carb is needed.
Check out "Zilla Dragin" in the Suzuki forum where I talked about the pros/cons of alky.
the500bansheepilot
Feb 5, 2002 03:18 PM
