lectrons
Old Aug 22, 2002 | 12:17 AM
02bansheeman's Avatar
i just bought a set of lectron carbs for my banshee my motor is compleatly stock does anyone know if it will run right on alky i will prolly get my head milled first anyways but will i need any port work before it will run right
Old Aug 22, 2002 | 02:19 PM
AlkyBurninX's Avatar
Portwork helps, but isn't neccesary. Milling the head is a must. You will need the added compression for alky to burn clean. I am not familiar with the Lectron pieces, but the trick setup for alky includes a booster jet. It is easy to blow a motor while trying to jet a 2-stroke for alky. A specifically designed carb is needed.
Check out "Zilla Dragin" in the Suzuki forum where I talked about the pros/cons of alky.
Hightower
Apr 27, 2004 09:19 PM
918sTaxi
Oct 30, 2002 11:41 AM
QUADLOCO
Sep 11, 2002 01:15 AM
Slobanshee
Feb 22, 2002 10:42 AM
the500bansheepilot
Feb 5, 2002 03:18 PM
