Green Spring
Old Oct 10, 2002 | 05:47 PM
MossMan84's Avatar
Default Green Spring
I have read alot of posts about the green primary clutch spring and alot of people say that they lose top end. I have installed one on my trailboss and I think that if anything I have gained top end. It's hard to tell, because I never clocked it before, but I am positve that I did not lose any. I'm pretty sure that before I put in the spring I topped out around 50. Is there a reason why diferent quads would see different top end results?
Old Oct 10, 2002 | 08:12 PM
Mudracer300's Avatar
well your sig says a aaen green spring if this is the green spring your talking about it maybe different than what others are talking about. im not sure but i think most of them are talking about the polaris factory green one??? just a thought
Old Oct 10, 2002 | 08:30 PM
ftwflh's Avatar
The polaris green spring works great in 2strokes but a white is better for 4strokes where trail rideing is what you do most.
Old Oct 10, 2002 | 08:49 PM
MossMan84's Avatar
Aaen green primary....stall preload-60lbs........stall increase-400 rpm.....full shift-200lbs.
Old Oct 10, 2002 | 10:24 PM
ChrisTurgeon2's Avatar
Is there a polaris part # for the white primary spring? I am very interested in ordering it, but my polaris dealer can't find a white primary spring!!
Old Oct 10, 2002 | 10:42 PM
PolarisMech's Avatar
any polaris sevice manual will list all the polaris springs and weights in the clutching section. along with their part numbers
Old Oct 10, 2002 | 11:22 PM
ftwflh's Avatar
Part # for white spring is 7041132
Old Oct 11, 2002 | 10:21 AM
SurferSam's Avatar
My book shows the white spring part # is 7041032. Is this a misprint? It's different from "ftwflh"'s part # of 7041132.
Old Oct 11, 2002 | 01:03 PM
GE4x4's Avatar
ftwflh has the right part # for the white spring.
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
rawbdiggity
Sep 7, 2015 12:05 PM
