Choke Springs....
Old Dec 4, 2002 | 01:57 PM
Fishhead's Avatar
Default Choke Springs....
Well it is happening... The good ole hanging choke!
The question I have is there anyway I could talk my dealer in to giving me the springs to put in? I dont have much confidence in them! I thought I had heard someone say they did this! Thanks for the help.....
Old Dec 4, 2002 | 07:33 PM
nyroc's Avatar
My dealer lets me do that. I guess it just depends on them being nice enough.
Old Dec 5, 2002 | 11:12 AM
Uinthas's Avatar
what are they symptoms of a hanging choke spring? Do you know if the 360 has the same spring? The reason I ask is
my choke does not work correctly, & my dealer doesn't want to deal with it & just says it works fine, so I guess it's up to
me to take care of. When I have my choke on, unless it's fully choked it just kills the engine, plus when it does work the engine is
not smooth at all & is very ruff, the pipe also spits out allot of black smoke.
Old Dec 6, 2002 | 12:23 AM
nyroc's Avatar
Weak springs cause one or both chokes to remain engaged, causeing rough idle, or slow idle, stalling, fouled plugs etc. It happened to 650's a lot since there is one lever and a single cable that splits into two cables. Some 650's needed stifer springs.
I don't think your 360 needs any springs. I don't know why your 360 does that. I thought I saw somewhere that the chokes can be adjusted using a jet or screw or something. I haven't ever had a choke prob and haven't looked at it.
Old Dec 6, 2002 | 11:22 AM
Uinthas's Avatar
Relating back to the problem with my choke, I found out by complete accident that if the fule is cut of to the carberator the choke works just fine. I was running the engine for a couple of minutes after shutting the fuel switch off last night, & then shut the engine off. Went back out a couple hours later after the machine was cold again (30 degrees out side) and forgot to turn the fuel switch back on and started the engine fully choked & the choke worked great, the engine ran smooth & the choke would work great at all levels. But once I turned the fuel switch back on, it ran rough again & would kill the engine unless the choke was fully engaged. Previously the choke has always made the engine run very rough & kill's the engine if the choke wasnt out fully. Does anyone have a possile soulution to this problem, or have any ideas of where I might start, I dont know much about carberators, & the dealer has been no help at all..
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
