SP 500 HO clutch kit
Old Jan 1, 2003 | 10:33 AM
bjn644's Avatar
Default SP 500 HO clutch kit
I want to put some 27" tires on my Sportsman and a clutch kit to help out with the oversized tires, can you guys tell me what kind of luck you have had with different kits or recommend a good set up just using different weights and springs, I tried a white primary spring with the stock tires and the belt slips when doing slow tight manuavers so I think the HO clutch would need some more weight, but anyway please let me know what brands of kits work and what doesn't, thanks.
Old Jan 1, 2003 | 10:51 AM
2manytoys's Avatar
The Heelclicker clutch kit would be your best bet. It will eliminate almost all belt slippage, and you dont have to shift into low nearly as much. It is a great kit. It is made for more extreem riding.Nothing else compaires to the Heelclicker.
Old Jan 1, 2003 | 08:06 PM
bjn644's Avatar
Thats the kind of info I'm looking for, keep it coming, thanks
Old Jan 1, 2003 | 10:06 PM
Bubba297's Avatar
Are you sure the belt was slipping, or was it that the white spring engages higher and shifts a little higher giving you a false sense? You have to build the rpms a little more to get the same results. Bubba
Old Jan 2, 2003 | 09:05 PM
bjn644's Avatar
It made kind of a chirping noise like it was half slipping if that makes sense, there was a guy on here awhile ago doing some testing on the Dalton clutch kit any more word on that set up ?
Old Jan 3, 2003 | 05:35 PM
500DUSE's Avatar
That would be me[img]i/expressions/face-icon-small-happy.gif[/img]
I havent gotten to ride much due to the holidays,
but I did get 30 miles on the Dalton last week-end.
I was in the swamps.
Absolutly NO problems whatsoever
This week-end I'm putting the H/C back on to try it with a 500 belt and 1/2gram to the shoulder to see what happens,stay tuned[img]i/expressions/face-icon-small-tongue.gif[/img]
#1The Heelclicker clutch kit would be your best bet. #2It will eliminate almost all belt slippage, and you dont have to shift into low nearly as much. #3It is a great kit. #4It is made for more extreem riding.#5Nothing else compaires to the Heelclicker.
#1-Why?
#2-Yes it will,and no you dont.
#3-Agree'ed
#4-Okay
#5-So far,I think the Dalton does
Old Jan 3, 2003 | 09:43 PM
bjn644's Avatar
Thanks for the reply, I will be very interested in the results of your testing, I most likely will go with the Heel klicker or Dalton but I haven't ruled out the EPI kit yet so if anyone can comment on that kit too it would be great, thanks again and keep those opinions coming.
Old Jan 4, 2003 | 06:08 PM
cooneyjr's Avatar
i put 27 inch mudzilla's and the heavey duty clutch kit from highlifter.com and it works great!!!!!!!!
butch
Old Jan 4, 2003 | 06:21 PM
500DUSE's Avatar
The H/L kit is the EPI kit
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
