SP 500 HO clutch kit
I want to put some 27" tires on my Sportsman and a clutch kit to help out with the oversized tires, can you guys tell me what kind of luck you have had with different kits or recommend a good set up just using different weights and springs, I tried a white primary spring with the stock tires and the belt slips when doing slow tight manuavers so I think the HO clutch would need some more weight, but anyway please let me know what brands of kits work and what doesn't, thanks.
, there was a guy on here awhile ago doing some testing on the Dalton clutch kit any more word on that set up ?
I havent gotten to ride much due to the holidays,
but I did get 30 miles on the Dalton last week-end.
I was in the swamps.
Absolutly NO problems whatsoever
This week-end I'm putting the H/C back on to try it with a 500 belt and 1/2gram to the shoulder to see what happens,stay tuned[img]i/expressions/face-icon-small-tongue.gif[/img]
#1The Heelclicker clutch kit would be your best bet. #2It will eliminate almost all belt slippage, and you dont have to shift into low nearly as much. #3It is a great kit. #4It is made for more extreem riding.#5Nothing else compaires to the Heelclicker.
#2-Yes it will,and no you dont.
#3-Agree'ed
#4-Okay
#5-So far,I think the Dalton does
Thanks for the reply, I will be very interested in the results of your testing, I most likely will go with the Heel klicker or Dalton but I haven't ruled out the EPI kit yet so if anyone can comment on that kit too it would be great, thanks again and keep those opinions coming.
cdstang
08-31-2015 07:52 AM
