Clutch is stiff
Old Jan 27, 2003 | 01:22 PM
Razorcat's Avatar
Default Clutch is stiff
Hey the clutch on my ds650 is a little stiff, is there an easy way to loosen it up a bit? Maybe it's just because it's new... It is also a little farther out than I'd like; I have to move my whole hand to pull it in... any way to decrease the distance from the grip to the lever?
thanks for any input [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 27, 2003 | 08:16 PM
Razorcat's Avatar
anyone?
Old Jan 27, 2003 | 09:19 PM
Oldmanracing's Avatar
Check the cable first:
1- Lossen to max cable at handlebar
2- Remove cable by motorcase
3- Remove cable at handlebar
4- By hand move cable up and down - a properly functioning cable can be pushed down by
light finger pressure.
If excessive drag - run a light penetrating oil into cable to clean it out - no drag
- re-oil with a light oil or synthetic oil that creeps
If cable is OK:
1- On clutch input shaft use a sharpie pen and mark its oreintation.(Mark on shaft and housing)
2- Remove clutch cover housing
3- Inspect splines on end of input shaft - if excessively worn or bent
- rotate shaft 180 degrees(good splines) and reassemble
- if shaft is good - inspect clutch basket for excessive
wear or bent
Old Jan 27, 2003 | 09:28 PM
Razorcat's Avatar
thanks Oldmanracing - I think I should have been more clear that this is a brand new bike (bout 8 hours on it). My bud bought a ds at the same time and his clutch is easier to pull in. It has a lot more play in the clutch lever, which makes it closer to the handlebar which makes it easier to pull in I think. Maybe it does need lubrication, I'll check it out
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
