cleaning front brakes
Old Feb 2, 2003 | 07:31 PM
packardbell15's Avatar
Default front brakes messed up?
i jacked up the front end of the 650 today, because i heard a noise when pushing the atv around
it is the front brakes i believe. when turning the wheels it sound like the brake is catching the disk and it is sticking or something. Is this normal and should i just not worry about it or is there a problem?
Old Feb 3, 2003 | 11:41 PM
still waiting for the part to come in and the new oil to get for the diff, but can still here those front brakes dragging. as my previous post states, i jacked the front end up and the tires are hard to turn and u can hear the brakes dragging. does anyone have a fix for this or is it normal, just started happening.
Old Feb 4, 2003 | 12:38 AM
NovaKaw650's Avatar
Check the disc brake pads, they may be worn out.
Old Feb 4, 2003 | 12:54 AM
grizzkiller's Avatar
my bro and friend both have 650 praires, both have lost their front brakes on the first squeeze in cold weather and one needs pads, he gets a squeel once in awhile. but your prob sounds like pads to me. good luck
Old Feb 4, 2003 | 09:28 AM
thats wierd it only has 300 miles on it an i did drive in cold weather this winter once and it was around 0. so that is why? is that a sign that you need new pads when it does that??
Old Feb 4, 2003 | 09:52 PM
im not having a good time with the dealer so what is the easy fix for this brake problem? is it just new pads or are the brakes dragging and how to fix it? i rather do it myself than have my dealer do it.
Old Feb 5, 2003 | 12:31 AM
grizzlytim's Avatar
Have you pulled a tire off to look at the pads? It may just be dirt. Try some break cleaner on them.
Tim
Old Feb 5, 2003 | 09:09 PM
thanks alot for the replies
i think im going to inspect the brake pads for dirt and clean them.
what brake cleaner should i use, any kind?
and how do u get to the point to get the pads off to clean them.
ive never taken off the wheel and brakes so how do u do it?
any response will be appreciated!
Old Feb 6, 2003 | 08:21 AM
monteSS's Avatar
Default cleaning front brakes
Are you sure it isn't just a little surface rust from sitting so long? (not sure whatr teh front rotors are made of) If that is all it is don't worry about it. Take it for a small ride using your front brakes ones in a while and if it goes away it was just a little surface rust no big deal.
AK47KID
Jul 23, 2015 09:21 PM
NLWarrior01
Jun 28, 2015 12:54 PM
scaldwellk
Jun 19, 2015 05:08 PM
gdmclnh
Jun 13, 2015 05:32 PM
CountryMiles
Oct 25, 2000 01:03 AM
