clutch help!!!!!
Old Mar 2, 2003 | 10:09 AM
BASSTOY's Avatar
Default clutch help!!!!!
ok i finaly took off the clutch and had no probs,,,, i thorughly cleaned evrything thing in there with brake cleaner and washed the belt in warm soppy water,,,,, i was too scared to take off the seconary because of the big spring that i felt behind it,,, is there anyone who can tell me a step by step to take it off? and what to look for,, ie. will the thing fall apart in my hands? or is it all ok and just remove the big bolt in the front,,, !!!!!
Old Mar 3, 2003 | 12:45 AM
Fango's Avatar
Just remove the the big nut...then you can remove the whole driven assembly. The spring is held in place by a retainer and will not fall off. If it does then you may have problems...[img]i/expressions/face-icon-small-wink.gif[/img] But that's all you should have to do.
Things to look for?? Excessive wear on the faces, greasey film, dirt, etc...
When you install everything make sure to use some Loctite 271 on the threads.
Old Mar 4, 2003 | 07:59 PM
Cat500i's Avatar
I must have missed the original question. Why are you pulling the clutches off?
Old Mar 4, 2003 | 10:23 PM
BASSTOY's Avatar
just to see the mechanics of it and to clean it just in case it needed it
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
