CAN SOMEONE TELL ME WHAT THIS PIECE IS.
Old Jan 10, 2000 | 12:18 AM
bigmanMH's Avatar
I have a 1984 200es bigred and My starter always just skipped around. Well then suddenly my rod went out and i needed to rebuild my bottom end and when my mechanic split the case he found this round heavy pice that was causeing in. I need to know where i can get one of these other than the honda shop because they are very expensive. ALso what is it called. YOu can see it at this site towards the bottom of the page
www.geocities.com/trikerider62467/62467.html
Old Jan 10, 2000 | 12:33 AM
feara400's Avatar
That piece is a diquadrolateral electromagnafluxulator. It goes between the semicondusive spankshaft and the transversal tri-dyno brake. Whatever you do--DON'T DROP IT! You could chip the alumnatripetal pearlescent finish.
Old Jan 10, 2000 | 09:24 AM
bigmanMH's Avatar
This piece is bad. I would like to know where i can find another one. NOt from honda they are two expensive. They want 100 dollars for one.
Old Jan 10, 2000 | 09:34 AM
Tree Farmer's Avatar
The Illustrated Parts Breakdown drawing from a Honda parts catalog, microfiche, or service manual identifies the part, the first two containg the part number also.
Sources: Honda dealerships, mail-order parts houses, junk yards (ATV "disassemblers" or "recyclers," if we must be politically correct).
Technical advice: Honda USA customer service, Torrance, CA--a really conscientious opeation trying to help.
Good luck!
Tree Farmer
Old Jan 10, 2000 | 01:17 PM
ecbaatz's Avatar
I am confused. You know it is expensive at the honda dealer but you don't know what it is.
How is the dealer telling you the price with out telling you what it is?
I am sorry but it does not make sense to me.
Any enlightenment would be appreciated.
Eric Baatz 1996 Suzuki KING QUAD Remember the KING Lives!!
[This message has been edited by ecbaatz (edited 01-11-2000).]
Old Jan 10, 2000 | 03:52 PM
Trailblazer96's Avatar
It looks like part of the starter drive commonly called a Bendix drive (I think) assembly. Did it have a gear on it and a spring loaded sliding shaft? If its not part of the drive its probably the brush holder. I can't tell because I can't see the other side.
Old Jan 10, 2000 | 04:28 PM
bigmanMH's Avatar
The reason i know how much it is because i brought the piece in the honda shop and they told me it would cost about 100 dollars for a new one. They never told me what it was called.
Is there any reason that i have to put a new one in if i just use the pull start.
Old Jan 10, 2000 | 06:09 PM
For $100 I would just use the pullstart. It doesn't need the starter on it to work right. If you take it off though cover the hole where it was with something so dirt doesn't get in.
Old Jan 10, 2000 | 06:47 PM
bigmanMH's Avatar
Thanks, I will put it back on but i just wont use the electric start
Oct 10, 2015 10:20 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
nastyblaster100
Sep 13, 2015 01:19 PM
mbriggs
Sep 13, 2015 10:47 AM
toonces
Sep 5, 2015 01:14 PM
