belt squeal
Old Mar 14, 2003 | 07:55 PM
Nightryder888's Avatar
Default belt squeal
i noticed the belt started to squeal yesterday. i measured the deflection today and it came out to be
1 3/8" can someone convert that to mm for me. thanks!
Old Mar 14, 2003 | 08:17 PM
kingmort's Avatar
Default belt squeal
1.375x25.4=34.925 mm
Spec, according to Nyroc is 22 to 27mm
Have fun
Old Mar 14, 2003 | 08:52 PM
Default belt squeal
wow, im that off! im thinking that ill take the bigger of the shims out, does that sound right or should i take them all out? thanks
Old Mar 14, 2003 | 09:42 PM
Scotia650's Avatar
Default belt squeal
Kingmort is correct on the specs and the manual states that a 0.1mm decrease in spacer thickness should decrease deflection by 1.3mm. You need to lower deflection by 13mm to get to the lower end of that spectrum so remove 1.0mm of spacers.
Hope this helps.
Old Mar 14, 2003 | 11:38 PM
jefffoxsr's Avatar
Default belt squeal
Under what conditions does the belt squeel?
Old Mar 14, 2003 | 11:44 PM
Default belt squeal
if i take off slow. its most noticeable in low gear. its kind of a duller noise then the kebc motor kicking in, it did it right before the kebc kicked in
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
