Shifting....use the clutch??
Old Mar 25, 2003 | 09:40 PM
s's Avatar
s
Default Shifting....use the clutch??
I got a warrior and I have always shifted by using the clutch every time I change a gear. Someone told me its ok to shift without using the clutch, that it wont hurt anything. I don't know much about them its my first manual shift quad and I really dont want to screw up the transmission. Does this hurt them or is it ok?
Old Mar 25, 2003 | 10:19 PM
Raptor58's Avatar
I use it all the time. Other people can shift without the clutch if they want but i think i will stick to using it.
Old Mar 25, 2003 | 11:46 PM
AustinONeal's Avatar
the only time i dont use it is when im racing or wheeling
Old Mar 26, 2003 | 12:45 AM
wheelinforlife's Avatar
Is it ok to do it on the ex?
Old Mar 26, 2003 | 01:52 AM
YFZRacer's Avatar
just my 2 cents
you should use the clutch and back off the gass a bit pretty much all the time its easier on you quad and it will last longer
the only time you can be hard on it is when your racing some people just let off the gas quickly and shift others like me keep it pinned and use the clutch
-cory
Old Mar 26, 2003 | 03:46 PM
Starky's Avatar
When I'm racing I often shift down going into a corner without using the clutch but I always use the clutch when shifting up. You can shift up without using the clutch, but why waste your trany.
Old Mar 28, 2003 | 12:14 AM
RepTaR660r's Avatar
USE THE FREAKING CLUTCH!!!!
Old Mar 28, 2003 | 12:19 AM
Ernie660R's Avatar
I use the clutch only to take off and down shifting.
Old Mar 28, 2003 | 12:35 AM
Lboy's Avatar
I got into the nasty habit of downshifting my EX with no clutch mostly cuz it was so easy to do.
It just slipped right into the previous gear easily.
In 2 years of doing this I have not hurt anything,but the clutch IS there for a reason.
on upshifts even when racing and wheelies,I use the clutch.
i find that if I hold the throttle wide open and smack a quick powershift,I gain some ground due to the revs flaring up a bit on the shift.
The machine will last longer if you use the clutch,so its a good idea to do so.
Old Mar 28, 2003 | 01:41 PM
QuadTeun's Avatar
If you're at the right rpm when shifting it won't hurt that much (when upshifting). I wouldn't recommend downshifting without clutch!!!
But to be honest, I always use the clutch. It is there for a reason..... [img]i/expressions/face-icon-small-happy.gif[/img]
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
