how does this thing work
Old Mar 29, 2003 | 02:07 PM
merlinthom's Avatar
Default how does this thing work
I have a 99 500 SP. The 4 wheel drive quit working and i'm just now getting around to trying to fix it. I was thinking that the front locked in at the front hubs, there's wires running to them. I was doing some other work on it and took the front hub apart and darn if I can see any locking device there. the front drive shaft turns all the time when its in gear and moving.
Help me out here how's this thing supposed to work and what do I need to be looking for.
Old Mar 29, 2003 | 03:18 PM
highwayman's Avatar
Try turning on your ignition and activating the all wheel drive button ( engine not running and in gear) there should be a plate that is that will stick to the hub where the rollers are. If every thing is ok there then there is a sensor in the rear end that senses wheel slip sends power up the propshaft to front end. If everything checks out then look for mech things like the rollers in the front hubs. Hope this helps I am fairly new at this but have read a lot on these forums.
Old Mar 29, 2003 | 03:21 PM
highwayman's Avatar
PS the front hubs are locked aith a small electo magnet, hence the wires
txkevin
Sep 21, 2015 02:02 PM
kwackermann
Jun 24, 2015 10:18 AM
BEEFKING69
Jun 17, 2015 12:38 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Steven Bandemer
May 27, 2015 07:39 PM
