Rear wheel side CV boot
Old Apr 4, 2003 | 04:15 PM
Dinospin's Avatar
Default Rear wheel side CV boot
I am trying to replace the rear wheel side CV boot on my Sportsman 500.Most of the posts i have read talk about a spring clip that must be removed in order to free the shaft from the transmission side, But i am trying to remove the shaft from the wheel side CV Joint. There is some play on the shaft but it will not come off.
Can any one help?[img]i/expressions/face-icon-small-blush.gif[/img]
Old Apr 4, 2003 | 08:01 PM
Predator03's Avatar
There is a snap ring holding that joint on. It is hard to see, you really have to clean the grease out to see it, especially if you don't know exactly what you are looking for. It's on the joint end where the larger end of the boot would be. If you clean the grease off the spline right there, you should be able to see. Hope this helps. It's easier to do than explain.
Scott
Old Apr 4, 2003 | 08:18 PM
Dinospin's Avatar
Found it!!! Thanks for the help.[img]i/expressions/face-icon-small-smile.gif[/img]
greg74
Sep 10, 2019 03:03 PM
rcappie4
Jul 18, 2015 07:51 AM
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
