whats with the 700 Belt???
Old Apr 5, 2003 | 04:00 PM
hAzArD's Avatar
Default whats with the 700 Belt???
why am i seeing/hearing bout people buying 700 belts and using them in other polaris rides (500 H.O, Xplorer 400, etc.) what is different bout the 700 belt than the other Polaris belts? what do you gain?
Thanks, Haz!
Old Apr 5, 2003 | 06:23 PM
hAzArD's Avatar
OH CMON someones gotta know, heck ive seen it on this forum before cmon guys please help me out here.
Thanks, Haz!
Old Apr 5, 2003 | 10:13 PM
Alpine2's Avatar
Well I run a 700 belt on my Scrambler I did it cause I like the idea it was spliceless and it had top gogs for better cooling , the top gogs also generate more air flow comin out of the exhaust for the clutch thus making it more unlikey of getting water or snow in. My results with it have been very good although it was not designed for the Scrambler I found I get better belt grip with it and may have gained on top abit but old belt was glazed abit from being smoked a few times so any new belt would have helped will I get another for sure if this one holds up good but I do not have enough miles on it yet to know for sure.
Hope This Helps
Old Apr 5, 2003 | 11:12 PM
NCScrambler's Avatar
I have also heard that it was a much better belt. My belt I use on my Scrambler is a top cog from Aaen Performance and I love it, so If that belt is anywhere close to it, it's gotta be good. If you could get that from Polaris for cheaper than aftermarket, I would do it too. Of course my belt is Kevlar re-infoced which eats up clutches, but It doesn't slip!! So, if the 700 factory is half as good without the kevlar it is better than the other factory belts. Anything is better than the factory belt though!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 6, 2003 | 10:47 AM
Farmr123's Avatar
It is stronger than the standard belt, and runs cooler. Lasts longer, and because it doesn't get hot as easy, usually gives more consistant performance.
Farmr
Old Apr 6, 2003 | 11:01 AM
hAzArD's Avatar
so you guys are saying, you dont have to adjust/modify anything to use this belt, will it rub on the outer case?
THanks, Haz!
Old Apr 6, 2003 | 12:38 PM
Farmr123's Avatar
It should fit OK, but keep in mind, it is designed for machines with EBS. If you don't have EBS, I am not 100% sure it will fit.
Old Apr 6, 2003 | 01:00 PM
Snowride's Avatar
Sometime in 03 Polaris released a spliceless belt that is the same compound as the 700/600 belt. The two belts differ in the side angle. Check to see if polaris has this belt for your scrambler. Running the wrong angle is not the best. If it were, why would Polaris realease another belt?
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
