Was reading in the Honda forum
Old Apr 11, 2003 | 05:22 PM
suds's Avatar
Default Was reading in the Honda forum
I was reading in the Highlifter honda forum about slack in some of the throttle cables. I was wondering if this was a problem for polaris scrambler 400's. Does this slack stop my machine from reaching its full potential, or is slack something that was designed into the machine. How do I adjust or check if I have the right amount of slackin my throttle cable,or should I even worry about it. Quad seems to work great I was just wondering
Old Apr 11, 2003 | 05:34 PM
NCScrambler's Avatar
That isn't such a big issue with the factory carb as it is withe an aftermarket carb. If your throttle is adjusted at the ETC like It should be according to your owner's manual, you will be ok. Aftermarket carbs, like mine are different though, as you have to adjust for more pull because the slide doesn't always clear the venturi.
Old Apr 11, 2003 | 09:38 PM
Quadfather's Avatar
You should have 1/8" of slack, or free play in your thumb throttle before you feel resistance. Some Hondas are shipped with 1/2" or more slack. Why? I don't know.
Old Apr 12, 2003 | 12:20 PM
suds's Avatar
great thanx for the info
Nondem
Feb 22, 2020 12:20 PM
GregM
Mar 6, 2018 06:53 AM
Scottma518
Jul 16, 2015 09:19 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
