Problems with Kodiak
Old Apr 14, 2003 | 03:39 PM
yguy's Avatar
Default Problems with Kodiak
I am having a real hard time getting my 96 kodiak to shift into reverse. I have to pull forward about 10 feet and then jam it into reverse. Can someone tell me how to fix this? It used to shift into reverse quite easily until i had a dealer give it a spring tune up. I don't feel like going back to him and was hoping i could fix this myself.
Old Apr 14, 2003 | 11:37 PM
robh's Avatar
is your idle up too high??
Old Apr 15, 2003 | 01:40 AM
mountainman610's Avatar
I have a 96 as well yguy.You have to have the foot brake pressed all the way down for it to go into reverse.I wired my switch back so you dont have to do that.Good luck
Old Apr 15, 2003 | 09:33 AM
semi's Avatar
wired the switch back
Old Apr 15, 2003 | 09:35 AM
yguy's Avatar
thank you for the feedback. my idle is up a little higher than normal, and i don't remember if i had the foot brake depressed. i think i did but will try it again. THANKS, i am new to ATV's so my knowledge is lacking about the subject. I just wasn't sure if there was some machanical adjustment.
Old Apr 15, 2003 | 10:23 AM
Yes Semi, if you follow the rear foot brake cable you will see that it splits and one of them goes to a switch when pulled allows you to go into reverse ( another useless safety item). I wired mine on so it allows you to go to reverse without having to depress the brake........Cheers!!
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
RedRancher
Jul 10, 2015 06:36 PM
