how to make a warrior fast!!!
Old Apr 21, 2003 | 12:13 AM
accorracer's Avatar
Default how to make a warrior fast!!!
what aftermarket parts or modifications can be done to make a warrior very fast?
is there a big bore kit, cam, exhaust, upgraded valve train carbuerator or what?
Old Apr 21, 2003 | 12:25 AM
rivermobster's Avatar
remove seat...slide a raptor under old seat...reinstall seat...your done!! [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Apr 21, 2003 | 12:50 AM
Coyotechaser's Avatar
In the July 2002 edition of ATV Action they had a ALBA Warrior 400. It boost the HP from around 18hp up to 29/30hp. ALBA 400cc Stroker kit for $1350.
Old Apr 22, 2003 | 12:18 AM
accorracer's Avatar
i see in your sig you have a blaster, is the blaster much faster than the warrior?
Old Apr 22, 2003 | 12:23 AM
hmmmm...to be honest...im not sure! but the blaster is way more fun to ride...the warrior is kinda like a tank. Most guys buy em for there wives to ride [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 22, 2003 | 01:07 AM
SLIM660's Avatar
CALL FOUR STROKE TECH. THEY DO A I BELIEVE IT WAS A 7MM STROKER THAT IS VERY FAST. I HAVE A FRIEND THAT OWNS AN ATV SHOP AND HE PUT ONE TOGETHER FOR A GUY AND IT WAS FLAT OUT AWESOME
Old Apr 22, 2003 | 01:24 AM
Mr45auto's Avatar
You could always drop the Warrior from a C130 at 10,000 feet. Fast, very fast... Okay, with minimal cash. Aftermarket pipe (supertrapp, alba, FMF) Drill 6+ 1" holes in your airbox lid, rejet the carb or buy the 36mm mikuni from Alba. Drop in the .390 lift webcam and add a high compression piston ( go with an overbore not a drop in ) For a sum of under $600 you can make it much faster. If you want a super low buck mod remove the baffle from your stock pipe and open up the airbox and rejet. Good improvement for under $10.
Old Apr 22, 2003 | 04:02 AM
JakalWarrior's Avatar
Port it completely, put in bigger valves with better springs, .450 cam, ton of compression on alcy carb, call FST and have them hook you up with 450-500ccs. Then toss in a boondockers nitrous system. Add a better clucth and if eveything holds together you can hit mach 1. \
If you want cheap, the Ablba cam and piston kit (lil over 400 bucks) mixed with some porting will yield ~30hp. As will the FWT kit for around the same price.
Reactant
Mar 30, 2022 02:08 AM
RickyMac
Mar 5, 2016 07:27 AM
Reactant
Jul 16, 2015 10:29 PM
ghost civic
Jul 15, 2015 10:48 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
