185 atc three wheeler
Old Apr 25, 2003 | 05:08 PM
bilcodybil's Avatar
Default 185 atc three wheeler
i need to know where are the timing marks are on a 185s three wheeler
Old Apr 25, 2003 | 08:54 PM
dzzy's Avatar
There are two lines on the flywheel, an F mark (for ignition timing), and a T mark (for cam timing). You view them through the "window" on the left engine cover (the one with the large flatblade plug). There is an O mark on the cam that faces a V notch on the top valve cover when the flywheel is in the T position. There is a line on the pulse generator that lines up with the line in the timing advance rotor when the flywheel F mark shows in the window. There are also two O's on the timing advance plate and rotor in case the timing advance was disassembled. It is possible to get this 180 degrees off and your bike will not start.
Old Apr 26, 2003 | 10:11 PM
bilcodybil's Avatar
thanks for the help it is so hard to find any one who knows any thing about three wheelers
Old Apr 27, 2003 | 07:50 AM
dzzy's Avatar
Your welcome bilcodybil. I've been a line tech for nearly 20 years now, more like 25 if you count my part time years. I used to work on atv's by the hundreds before anyone even had a four wheeler out! I remember them well and fondly. Any more questions about your 185 post them, and I will try to help.
Old Apr 30, 2003 | 02:42 AM
bilcodybil's Avatar
i put it in time but it still will not start. how much comprestion should it have because i took the head off and the rings looked to be in good shape.its getting spark but it will not hit or back fire or do any thing the plug is getting gas on it.would it back fire if it had a bent valve. thats the only other thing i can think of. i was riding it and it just acted like it ran out of gas so i thougt it jumped time .any ideals?
Old Apr 30, 2003 | 08:28 AM
dzzy's Avatar
If the cam chain jumped and was actually out of time, a valve is likely bent. Usually this is obvious via compression test, your compression will be near zero. Anything over 100psi and it should at least run. An engine needs compression to backfire.
Old May 12, 2003 | 01:12 AM
bilcodybil's Avatar
just wanted to let you know i put a new head on i got from local bike salvag yard and now it is nunning as good as ever just wanted to say thank you for all of the help couldn't do it without you
Old May 12, 2003 | 01:26 AM
TrickTrikeATC410X's Avatar
hey bilcodybil, i have had quite a few 3 wheelers in my day and know alot about them. if you have any questions just let me know and i'll try to help. at first to me it sounded like you had a bad stator coil but it looks like you've fixed it. great work. i ride a 350X thats now a 410X. its a beast. just thought you would like to know.
Old May 13, 2003 | 11:50 AM
bilcodybil's Avatar
i did have a bad stator when i got the three wheeler it was the first thing that i changed.when i pulled the head it had a impact mark on both of them so i changed the head and now i am good to go. but thanks for the help
wrencher82
Sep 30, 2015 04:27 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
dakotah
Sep 26, 2015 04:25 PM
wrencher82
Sep 24, 2015 03:39 PM
