black spring or shim???
Old May 1, 2003 | 11:19 PM
trailride's Avatar
Default black spring or shim???
my 650 is squeaking on tackoff should i reshim it or will installing the black spring probably fix it
Old May 1, 2003 | 11:49 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Take out the shims and put in the black spring. I just did mine(mine squeeled too), and it was well worth it. Just make sure you get a really good set of snap ring pliers. Mine broke taking off the circlip.
Old May 1, 2003 | 11:51 PM
Tonerpuke's Avatar
Since you have to pull the original secondary spring out to re-shim or remove a shim, it would be time and money well spent to put the black spring in at the same time.
Old May 2, 2003 | 12:31 AM
Nemmeh's Avatar
Both... you must do a belt deflection (shim) adjustment, installing the black spring will not solve the squawk problem. That is a belt deflection issue that must be resolved by adjusting the thickness of shims.
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
