Front End Locker
Old Jun 12, 2003 | 07:27 PM
NWThunting's Avatar
Default Front End Locker
Ok OK, I know its been posted a million times, but I was out last night and tried and tried to see how this "Torque sensing" diff works. I couldn't see how it locked up anything. Many times I was in 3 wheel drive in the sand. Many times I had all 4 going, but there didnt seem to be any consistency. I read a review on the 500 and they said all you might need to do is touch the brake quicky and the front end will lock. It didnt seem to work. Two Questions: Can someone explain how that front end works? Is it just a limited slip? Or is it slightly better?
Also, Can you get a locker for it? If yes, from where?
Thanks,
Old Jun 12, 2003 | 10:08 PM
GUTTJR's Avatar
from what i have been told, you have to slightly hold the brake lever in and that will get all four tires to turn. I have never tried this so don't quote me that this works. otherwise it is just a limited slip three wheel wonder!
Old Jun 13, 2003 | 12:09 AM
Cat500i's Avatar
Its a clutch pak design so using the brakes won't help. You'll have to live with 3 wheel drive or lock it. Ask Catkrazy or ODB about locking the frontend. (Both in this forum).
Old Jun 14, 2003 | 12:52 AM
Olddirtybastard's Avatar
NWThunting- The only Torque sensing the Cat front diff does is stop pulling the tire that senses torque. The Cat front diff is just a spider gear differential with clutches at each end. Playing with the brakes will not work most of the time. It is likely that it will 3 wheel most of the time and it will only get worse as the clutches wear.
If you want a locker, the only option at this time to put a spool locker in it. Don't expect to see anyone come up with Detroit locker anytime soon.
Going down by the cheapest first these are the options.
1.You can weld the spider gears together.
2. Order a spool for the back and put it in the front.
3. Get Dirty Howie to cut it open and put one of his lockers in.
I would recommend # 2 as you can swap your factory 3wheeling assembly back in if you don't like the hard steering.
OR swap in A King Quad front diff, but thats a whole nother story.
Old Jun 14, 2003 | 11:02 PM
SUZVINSON500's Avatar
Actually pressing the brake does work. If one wheel is spinning faster than the other than there is less resistance on the spinning wheel, if you apply the brake then it takes less force to slow the spinning wheel than the one not spinning there for sending the power to the wheel with traction. It isn't 4 wheeldrive but it is better than 3.
Old Jun 19, 2003 | 12:16 AM
crittergetter's Avatar
i would like to here more about that king quad front diff in the 500i
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
