Clutch Udjustment...HELP
Old Jul 10, 2003 | 03:51 PM
Cancat's Avatar
Default Clutch Udjustment...HELP
I need to know how to adjust the fluid clutches on a 250/300 Arctic Cat Manual shift. If anyone knows please help, the cat is slippin'.
Thanks to all.
CanCat
Old Jul 10, 2003 | 08:11 PM
Bigcat's Avatar
Cancat
Adjusting Clutch...250/300
1. Using an impact driver, remove the cover. Account for O-ring.
2. Loosen the jam nut securing the adjustment screw.
3. Rotate the adjustment screw clockwise until it stops.
4. Rotate the adjustment screw counterclockwise 1/8 turn; then lock the jam nut securing the adjustment screw.
5. Secure the cover making sure the O-ring is properly positioned.
Now it should be adjusted correctly, take it for a test drive to ensure accurate adjustment.
I hope this helps. How many miles on the engine? And if it still silps, the plates are worn out or you are not using the proper oil. If you are using a Synthetic oil, it must be wet clutch approved..
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
