650 icm power pak module problem
Old May 31, 2004 | 03:31 PM
  #21
Wookie's Avatar
Default 650 icm power pak module problem
Peacemkaer,
You have a new CDI and your bike went into limp mode? Is it a Dynatec CDI? Dyna has eliminated the circuitry for the limp mode and the reverse limiter in there CDI so I dont see how this is possible unless it is someone elses or stock. If it is a stock unit you cannot reset the limp mode if the belt switch has been tripped. You need to remove the cover and reset the switch first. I believe that the AC service manual states that the belt drive cover needs to be replaced if the belt switch is tripped but I cant imagine that this is true.
Rich.
Old May 31, 2004 | 06:43 PM
  #22
DaveB's Avatar
Noooooo...... I just put a new primary spring in mine this morning so I had a close look at things. The switch can me tripped physically by a loose belt or by a cord hanging off a belt. The system is good because it forces the owner to physically look at the belt when re-setting the switch. Of course, as we all know, the system is flawed as it trips for no apparent reason all the time. But no, the cover doesn't have to be replaced, just opened up.
Old Jun 1, 2004 | 01:36 AM
  #23
weez440's Avatar
hey limrok that is a cool idea you got with the dual exhaust i bet that sounds awesome i was gonna fabricate something like that for mine wanted to go with one pipe out each side and well i got arctic cat and polaris parts pretty cheap cause i live about 15 min from the polaris factory and about 40 min from the arctic cat factory and know alot of ppl who work at each place and bam everything is 25 or 30 percent off i can even get machines from salvage at arctic cat very cheap through ppl i know but you don't know what you will get it is everything from test machines to lemon's and trust me bout putting the black spring in the secondary clutch and taking a shim out it does tighten up the belt alot and will add life to it and i am patiently waiting for my dynatek cdi i am so excited i feel like i am 8 the night before christmas but will let yall know how that goes but ride safe everyone
Old Jun 1, 2004 | 08:18 AM
  #24
DaveB's Avatar
Darn Weez.....we gotta learn ya some punctuation! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 1, 2004 | 11:29 PM
  #25
Wookie's Avatar
Weez,
That sure is one long sentence. I think you might be just a little to excited there.
Rich.
Old Jun 2, 2004 | 01:09 AM
  #26
weez440's Avatar
Sorry guys. I am not used to capital letters or punctuations. I usually got like 5 things going on, on this internet at the same time and I was always really bad at grammer as you can probably see. Well i must be going now I will make sure to try to speak in a more grammical fashion from now on to make yall happy. TTYL
Shane
Old Jun 2, 2004 | 06:05 PM
  #27
DaveB's Avatar
Just teasin ya ,pal! Keep up the positive input!
Old Jun 2, 2004 | 10:03 PM
  #28
sledn's Avatar
Don't have a Cat,but can you guys just unplug the belt sensor or short it out to bypass it ? Seems like a headache until they fix the problem.
Old Jun 3, 2004 | 12:43 AM
  #29
limrok's Avatar
Weez..
.......The exhast does sound good...and i did have the pipes go out under the bummper.on both sides,i used crome pencil tips.also guys.u can bypass the belt switch.....there is a conector gojg to thew switch.un plug it and puta loop wire on the engine side......it will bypass the limiter ann no more limp mode....alos there is a a reset ..key for the kawi belt drive.....if u go to a kawi dealer u can get a reset key.it is a loop wire... wire and u have to follow the instructions...my Arctic cat dealer gave me one when i bought the bike.....if u need to know more............u can email me...at...rod.donna @sasktel.net.............and leave me a number . i will send u my phone number so i can explain it better.....Thank and have a good day......may u all have good riding
Old Jun 4, 2004 | 01:18 AM
  #30
weez440's Avatar
Ok everyone trying to use capital letters now and punctuations marks lol. Anyways I have been contemplating putting a dual exhaust system on my ATV I am willing to bet there isn't but a handful of ppl who have something like that and you said there is no rejeting or nothing so that would be great. About that limp mode apparently if you put in the dynatek CDI it will cure it got one on the way not here yet just curious how long it takes them to send it i never did get a confirm e-mail about anything hopefully it will be here soon can't wait.LOL i know you guys were just yanking my chain but it is easier to type not usuing all that punctuation and stuff but it is harder to read but goot luck to yall.
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
