How can you tell if you need a new belt?
Old Aug 15, 2004 | 10:47 PM
ng's Avatar
ng
Default How can you tell if you need a new belt?
Mine has 100 miles on it,It's slipped 3 or 4 times and I'm taking it in for the first service and I'm having the black spring installed.How can you tell by looking if I need a new belt,The dealer will be able to snow me because I don't have a clue. Thanks for any advice.
Old Aug 15, 2004 | 11:32 PM
Wookie's Avatar
You really can't tell if it has been burnt or not sometimes. The actual surface of the belt will become glazed and or hardened and will lose it's abilities to drive the pulleys without slipping. Your best bet is to just suck it up and replace the belt while they install the black secondary spring. They should also remove the thinner shim out of the secondary pulley ( the .8mm shim) since they also need to take the pulley apart to install the spring. Removing the shim will put your belt on the tight side of the belt deflection spec. This may cause your belt to squeek slightly while idleing in gear. This isn't a bad thing as long as the ATV doesn't try to creep in gear. Just make sure that you take the tranny out of gear and put it in neutral if your going to let your bike idle for extended periods of time. Chances are your belt is on the way out if it has already slipped a few times. If you don't replace it now while your doing this you will most likely end up being dissapointed with the service and it would only be your fault.
Good Luck and Happy Trails,
Rich
Old Aug 16, 2004 | 12:02 AM
weez440's Avatar
hey ng well your module will be sent in the mail tomorrow sorry bout the delay darn post office and well one thing with my belt i really started to notice a drop in power and performance and i put in the new belt and it came right back again and if i leave mine idle in low range it doesn't squeel the belt but sometimes it will roll ahead slowly
Old Aug 16, 2004 | 08:15 PM
ng's Avatar
ng
Thanks for the advice guys.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
