Temp problems
Old Dec 22, 2004 | 04:42 PM
sbailey's Avatar
Default Temp problems
My temp light comes on after riding for 20 minutes. I changed the oil, the radiator if full. I have 98 454 4x4.
Old Dec 23, 2004 | 07:05 PM
vampire's Avatar
Is your thermostat opening up and letting water cir. though the engine check the rad. out for water movement . 2 nd check out the temp light switch it is a little brass single wire switch
Old Dec 23, 2004 | 11:39 PM
Bear4570's Avatar
You need to find out if the engine is actually getting hot. Does it smell hotter than normal? Does the engine seem to be radiating more heat? I have an infarred temp sensor that I check temps with. Last time I had a temp light on the engine temp was only 197 degrees. The temp sensor was bad. Even a short can turn on your light so first find out if it is really hot.
Old Dec 23, 2004 | 11:48 PM
86LT250RFatty's Avatar
smell hotter? put ur face on the header, if it burns, its hot. [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Dec 23, 2004 | 11:58 PM
Bear4570's Avatar
I like that! LMAO But you better be careful, some dumba$$ will do it.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
ltrmc02
Jul 22, 2015 04:50 AM
hondarider1234
Jul 21, 2015 11:53 PM
