Heated grips Burned up!!!
Im not trying to deter anyone from buying these heated grips and thumb throttle, justing letting everyone know of my experiance with them. I also want to express my dissatisfaction with Arctic Cat in the way they treat their customers. If a part is going to be non warrentied if installed by a do it yourselfer then it should be explained in the paperwork or even before you buy them. I take great pride in doing the stuff i do on my machine. The directions are not hard to follow its just the time and the dis-assembly of the atv that takes time. My dealer is not right next door, its a 45 min drive , so figure that money on top of the dealers charge for install , its not really worth it for a 30 day warrenty!!!!! Mr tommy maybe you will have better luck with your set , they are really nice. Honda buster im not saying they are all bad but i feel the set i have does have a problem, when you follow the instructions to a T then double check everything . Whodatindamud definitly go ahead and put them on , i was a little uneasy at first but after doing it they went on great,the thumb throttle is the hardest part, you have to melt the rubber/plastic cover over thumb throttle, other than that it was straight forward. You know it is sad that you are penalized these days for doing things on your own. I think A/C should take a lesson from the home depot/ lowes of the world that promote doing things yourself or the pep boys / autozones of the automotive world . I will buy more accesories if i spend less money on installation .
Jeff Roper
02-01-2022 11:48 AM
Sw00p
09-24-2015 02:50 PM
